MGW or Steeda Tri-Ax
RE: MGW or Steeda Tri-Ax
I have an MGW and a Hurst in my cars. I like them both. You should consider the Hurst also. I ran the Hurst for 11 years before putting it into my wifes car and going to the MGW. Either shifter will not be disappointing.
"Just FYI, that noise isn't constant so don't think you will hear it 100% of the time. I only hear it if I am down shifting to slow down, or am running 5th gear at ~1500rpm for cruising"
You are correct...
You are correct...
i had the steeda and hated it broke a new tranny thinking it was cuz of the shifter. it only lasted 1 month had the tranny fixed and put the stock back in and havent had a problem and its easier to hit gears with the stock one the only thing i did was used the shifter handle off the steeda on the stock bottom. just my 2 cents
I'll be getting an MGW once I scrape some extra cash together (Christmas money? ). I wanted the Tri-ax at first but after seeing how solid the MGW looks compared to the Steeda and all the positive reviews I changed my mind.
