help with paint
Old Nov 24, 2007 | 12:53 PM
djcondo's Avatar
djcondo
Default help with paint
this winter i am painting my mustang and i was wondering what i should do with the trim and such. I have the car stripped rite now but, the gt moldings are not the easiest thingto take off and i would not want to ruin the paint by flexing them when i put em on and stressing the paint. should i prime everything and then put the bumpers and trim back on and then paint or do them seperate with the flex additive and then assemble the car after. this is my first paintjob so any suggestions will help. thanks.
Old Nov 24, 2007 | 02:16 PM
ALMOST STOCK's Avatar
ALMOST STOCK
Default RE: help with paint
Paint things separately, and then reattach them after the paint has dried throughly.
Old Nov 24, 2007 | 11:33 PM
djcondo's Avatar
djcondo
the paint on the trim wont stress crack with that flex additive? also wouuld i prep the urathane parts the ssame way that i would prep the body and use the same primer.
Old Nov 25, 2007 | 12:04 PM
ALMOST STOCK
I sent my car to the painter with all the molding off and he took it from there , prepping and painting the different moldings. When I got my car back I put all the molding back on and I never had one problem stress cracks. As far as prep work on urethane moldings I know that different manufactures have different methods because there was a prep sheet in the box with my Cervini Stalker telling whoever was going to do the prep work to follow these instructions.
Btw. if you already have the door moldings off make sure you remove thethin metal pieceon the back side from the molding, otherwise you'll never get the moldings to lay flat.
Old Nov 25, 2007 | 12:09 PM
djcondo's Avatar
djcondo
cool thanks for the heads up
guitarman376
Oct 11, 2015 01:47 AM
Oct 1, 2015 09:29 AM
mungodrums
Sep 28, 2015 10:54 PM
GLOCKer
Sep 28, 2015 07:36 AM
mustangchef
Sep 4, 2015 08:08 PM
