hiding wires
mmangt91, just a suggestion but if you were tostart on the passenger side first (less wire harnesses and wires to deal with) it will give you a good idea of what you need to do the drivers side.
Another suggestion is..As long as you have the old plastic shielding off main harness which expose the wires to the passenger side and drivers side try pulling those wires to the side the wires need to go, either drivers side or passenger side. This helps in lengthening those wires so that later you shouldn't’t need to cut and lengthen any wires.
jwog666
Dec 27, 2021 08:09 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
