cam question
Old 12-01-2007, 08:54 AM
my77stang
my77stang's Avatar
Default RE: cam question
maybe a B cam? maybe?
my77stang is offline
Old 12-01-2007, 11:22 AM
bouchermb
bouchermb's Avatar
Not worth it. I'd do about 10 other things before I'd go this route based on your current mods.
bouchermb is offline
Old 12-01-2007, 12:02 PM
hatchdemon89
hatchdemon89's Avatar
true that stock ive seen people have a e cam but upgraded there srpings for better lift get a cheap set of gt40ps an go with a f cam u wont be dissapointed
hatchdemon89 is offline
Old 12-01-2007, 04:33 PM
FoxGT
FoxGT's Avatar
I've been running an x303 for well over 20,000 miles with stock pushrods & valvetrain. 5.0m&sf tested the letter cams on a stock engine, it came out on top. They tested a custom grind & it came out a few hp more than the x though. I would recommend at least changing the intake manifold, it's not necessary though. I run 12's with my stock heads. x303, exp intake, full exhaust & quite a bit of timing. stock suspension & street tires too
I would definitely recommend putting some money in the valvetrain though if you do run a bigger cam. Mine is going through hell right now. Only reason i'm not too concerned about it is I've almost got a tt351w engine finished & ready to go in.
FoxGT is offline
Old 12-01-2007, 07:04 PM
Joel5.0
Joel5.0's Avatar
ORIGINAL: FoxGT
Joel5.0 is offline
Old 12-01-2007, 07:12 PM
my77stang
my77stang's Avatar
the X303 is .542/.542, there is no way you have stock valvetrain. I have done literally 100's of sets of SBF heads and I can tell you the stock springs will bind @ approx .500 which is why .475ish is the MAX lift that should be used.
you sir, are a dumbass
Old 12-01-2007, 07:29 PM
3stangs
3stangs's Avatar
well i got an extra set of tw heads but the valves are bent. Guess i need to pay for a new set of valves for them.
3stangs is offline
Old 12-01-2007, 08:44 PM
my77stang
my77stang's Avatar
FYI, Ferrea makes the best valves you can buy
Old 12-01-2007, 10:13 PM
gearbanger
gearbanger's Avatar
wtf? no wonder my car kinda dies over 5,000 rpm e303 cam with 1.7s rr's and stock valve train. they toldme iwould be fine[:@] ... tha means there romm for improvement
gearbanger is offline
Old 12-01-2007, 10:18 PM
91hatchgt
91hatchgt's Avatar
ORIGINAL: gearbanger
YES! I bet if you changed the springs, it would feel like you picked up 25 HP.
91hatchgt is offline
Quick Reply: cam question
