SOS!!!
Old Jan 9, 2008 | 11:28 PM
86 5.0L's Avatar
86 5.0L
Default RE: SOS!!!
when you start it next time look for excessive smoke from the engine bay or tailpipes
Old Jan 9, 2008 | 11:29 PM
Albizo66's Avatar
Albizo66
Default RE: SOS!!!
ORIGINAL: mjr46
ORIGINAL: Albizo66
my buddy came over and we found the problem...my smog pump delete thing is totally f*cked...so the belt jumped off, i lost all power components, and it hit an anti-freeze line thats why im leaking it....fun fun fun
so tmrw its off to autozone to get a smaller belt as a quick fix...then i will order a new smog eliminator from 50resto, along with a new tensioner, and put the bigger belt back on..
the smog eliminator pulley works great.. that's what I used and no more belt issues and it has a real clean look to it also
which one should i get?
this one:
http://www.latemodelrestoration.com/...1&comp=LRS
or this one:
Old Jan 10, 2008 | 12:05 AM
lxman1's Avatar
lxman1
Default RE: SOS!!!
I'd get the second one. or just run a 77" belt like I do.
Old Jan 10, 2008 | 12:16 AM
Albizo66's Avatar
Albizo66
Default RE: SOS!!!
ORIGINAL: 86 5.0L
when i started it to move it from the street to my driveway, didn't notice any smoke at all, which made me happy...its now sitting in my driveway, still leaking antifreeze..
so tomorrow im going to autozone telling them i need a belt for a 89 5.0 mustang with no A/C..then i'll run that belt on everything but the busted smog eliminator; will be a quick fix untill i get the new eliminator..then ill put some antifreeze in it, and limp it up to the shop i go to and have them fix the line that the anti-freeze is leaking from
Old Jan 10, 2008 | 03:13 AM
bikeboy587's Avatar
bikeboy587
Default RE: SOS!!!
similar thing happened to me in my old v6, the idler pully siezed and threw the belt, but luckily i was only 1.5miles from advanced auto so u pulled into the store just asthe car hit the red on the temp gauge and changed the pully in the lot
Old Jan 10, 2008 | 06:52 AM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
Default RE: SOS!!!
ORIGINAL: Albizo66
ORIGINAL: mjr46
ORIGINAL: Albizo66
this one:
or this one:
either will work..however I liked the looks of the ford racing one better so i got that one
Old Jan 10, 2008 | 07:25 AM
Albizo66's Avatar
Albizo66
Default RE: SOS!!!
ORIGINAL: mjr46
ORIGINAL: Albizo66
ORIGINAL: mjr46
ORIGINAL: Albizo66
this one:
or this one:
this one?
i was up all last night just praying that i have no engine damage from the overheating....this is just one thing after another...one minute im up cause i passed inspection, the next im at rock bottom cause this happens
Old Jan 10, 2008 | 07:29 AM
blk40th's Avatar
blk40th
Default RE: SOS!!!
yea man i hate my car. i have non stop problems. when i fix something, something else goes wrong. im buying another car and parking this piece of S***.
Old Jan 10, 2008 | 07:57 AM
lxman1's Avatar
lxman1
Default RE: SOS!!!
You sure that belt will work? I used a Gatorback belt 770K6 when I removed my smog pump. It is close between the idler and waterpump, but works fine. Mine's been on about 6 months with no problems.
Old Jan 10, 2008 | 08:27 AM
QatarStang's Avatar
QatarStang
Default RE: SOS!!!
Hope you didn't hurt anything too badly when it heated up.......250 is pretty damn high, and if it was pegged at it the temp was probably even higher.....
