302-351C Swap (pics)
Old Jan 14, 2008 | 04:57 PM
68CSTANG's Avatar
68CSTANG
Default 302-351C Swap (pics)
Ive debated about this for months now about what to do with my LX and Ive decided to build a 351C. This could probably go in the 351 section but I would rather keep it here if I can. I just got the heads a few days ago and have only had time to start sandblasting on one of them. Once I get done, they will be sent to the machine shop, along with the block. Im hoping to have it done late summer/early fall.
The engine:
-1972 XY Std bore Cleveland block (high nickel)
-1972 4V closed chamber heads (2.19/1.60 valves)
-I have a Weiand tunnel ram that I used on my 68 but I doubt Ill use it for this...Im really trying to find a Holley Strip Dominator
-Jay Allen cam
-Foged pistons
-H beam rods
-Stock crank
-Stud mount RR
-ARP head/main studs
-1 7/8 full length headers (Ill have to fab up an X pipe but Im keeping the 3" dumps)
-Milodon Oil pan
-Small nitrous kit (maybe 100-125 shot)
-MSD ignition setup
Tranny:
-Im rebuilding a C-4
-Decent stall
-Shift kit
Other:
-While the engine is out Im going to paint the engine compartment
-Cowl hood if the carb wont clear
I think the car is a pretty good foundation:
-Lakewood 50/50s and 90/10s
-Lakewood "Traction Action" lift bars
-Rebuilt rear end with 4.10s
-Ford Racing upper control arms
-Eibach drag springs (with airbag)
-Battery relocated
-6pt rollcage
-Tubular Engine cradle
-Subframes
-MT ET Streets
I think it should be interesting...not too many Cleveland foxes running around...Ill take alot of pics and post them up here..Tell me what you guys think
Old Jan 14, 2008 | 04:59 PM
68CSTANG's Avatar
68CSTANG
Default RE: 302-351C Swap (pics)
I havent had time to really clean any of it and I only got part way done sandblasting one head today so everything looks crappy...
Old Jan 14, 2008 | 09:53 PM
cleanfitty's Avatar
cleanfitty
4 bolt block?
Old Jan 14, 2008 | 10:14 PM
my77stang's Avatar
my77stang
those heads are sex. dont forget to have hard ex seats installed
Old Jan 14, 2008 | 11:04 PM
68CSTANG's Avatar
68CSTANG
Haha thanks 77, and actually midway thru sandblasting them the local performance shop called me and said that they have some aluminum heads and intakes for a Cleveland that they are trying to get rid of so Im gonna go check it out..no its a 2 bolt..Ive ran a 2 bolt in my 68 for years without any problems so Im a believer
Old Jan 15, 2008 | 09:55 PM
68CSTANG's Avatar
68CSTANG
Has anyone on here done this swap before? Im curious about hood clearance...I doubt Ill be able to use the stock hood but it would be cool if I could..
Old Jan 15, 2008 | 10:45 PM
bighungrymatt's Avatar
bighungrymatt
Good luck with the swap. I haven't read too much into the 351C swap, I will be doing the 351W swap soon. I read you CAN fit the 351W under a stock hood
Old Jan 15, 2008 | 11:08 PM
68CSTANG's Avatar
68CSTANG
Thanks matt, are you gonna run a carb setup or sre you sticking with EFI? Its hard to find much info on this swap...a 351W is def alot more popular but I know Clevelands better than anything else...and itll be something different...we'll see how it turns out..
Old Jan 16, 2008 | 10:25 AM
bighungrymatt
I will be staying FI.
Yeah I think someone else is doing that swap at the moment too, I remember reading it somewhere...
good luck
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Bokeo
Oct 10, 2015 08:28 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
guitarman376
Sep 30, 2015 05:54 PM
UrS4
Sep 30, 2015 10:13 AM
