Mcleod Clutch Users
Mcleod Clutch Users
Anyone around here running one? Im looking at there regular street series stuff. I had a spec stage 2+ but after pulling the trans out the disc doesnt have much life left and ive only had it like a year.. So ive narrowed it down to Mcleod and RAM.. no CF.. opinions on either clutch are welcomed!
RE: Mcleod Clutch Users
I'm running a McLeod hydraulic clutch setup with a Wilwood m/c, and it's very issue free, so I imagine their clutches are good quality as well. And why not CF clutches? And if your Spec wore out after barely a year then you either have your clutch adjusted wrong, don't know how to drive a stick, or had the wrong clutch.
I have had a couple Rams and I won't buy anything else. I have a 98794T in my car now and it is great. I have never personally owned a McCleod but some of my friends have in Chevy's and have had no problems.
The spec clutches do not have much material above the rivets when new. When i pulled my engine to have it machined to a one piece rear main i had the same concern as you. I call spec to ask how thick it should be, it was something in the thousands. I measured mine and it was just shy of that. The material that's used doesn't wear much.
BeatnikFink
10-01-2015 08:00 PM
junior04
09-28-2015 10:53 AM
