Mild performance upgrades ?????
Old Feb 6, 2008 | 11:55 AM
TexasJeff's Avatar
TexasJeff
Default Mild performance upgrades ?????
Hey Guys,
I am very new to the 5 literFord, I have a 1990 GT convertible with 120,000 that I just bought, I would like to improve
the performance a little. I was thinking a cold air intake, exhaust, and maybe a chip. I am not trying to make a drag
racer or anything just want a little more power. Can y'all tell me if I am headed in the right direction, or should I pursue
other areas.
Thanks, Jeff
Old Feb 6, 2008 | 11:59 AM
91hatchgt's Avatar
91hatchgt
Default RE: Mild performance upgrades ?????
Don't waste money on a cold air, because the stock airbox can support a lot of power. Just throw a K&N filter in the stock airbox. A full exhaust system will benefit you (headers, midpipe, and catback) but will only net you like 10hp on a stock 5 liter unless your exhaust is clogged or something now. Gears are the best bang for the buck, I would do 3.73's, you should definately be enthralled with those improvements.
Next you would be looking at Heads, cam and intake. But that's for a lot more power. Just letting you know now, because with the first minor mods, you are going to get hooked. All of us here are.
Old Feb 6, 2008 | 12:07 PM
Maxwelhse's Avatar
Maxwelhse
The really cheap and simple things I've done to my car that made me happy:
Air silencer delete (free)
SN95 70mm MAF ($35)
180 Degree thermostat ($15 with gasket)
On a total butt-dyno scale, I'd say those 3 things netted me about 5hp.. Its seems to pull harder from 4k-5k than it did before.
Simple stuff like new plugs, wires, cap/rotor, and fuel filter may wake your car up too. All that stuff could be 120,000 miles old.
Old Feb 6, 2008 | 12:10 PM
camaroeater's Avatar
camaroeater
ORIGINAL: 91hatchgt
+1 ^^ IMO i would do a H pipe w/ catback(all 2.5" piping), then gears.
Old Feb 6, 2008 | 12:11 PM
hatchdemon89's Avatar
hatchdemon89
He's right look for a set up gt40's or gt40p heads an a nice cam like i like the Fordracing cams everyone says there outdated but they've been around a long time so thats makes up alot to me I love my Fcam just set yourself a goal like some of us to like I wanted atleast 300ponies an im there with my setup,and thats a a real cheap buget cheaper than most guys.But im happy with my mods.
Go Like 91hatchgtsaid HCI swap look for a bigger maf house,throttlebody,an 24lb injectors an 3:73 gears u'll be happy with that!
Old Feb 6, 2008 | 12:43 PM
bighungrymatt's Avatar
bighungrymatt
yea put some gears and full exhaust on
Old Feb 6, 2008 | 02:18 PM
Dave93VertGt's Avatar
Dave93VertGt
Hey Jeff are u running a 5-speed ar auto?
if ur running, auto... then get a 3500rpm converter for tranny, tranny cooler, shift kit.
i have 3.73's and luv em, bbut i shoulda done 4.10's and reccomend this be ur first modification.
next i recommend underdrive performance pullies; fender style cai, advance timing to 14 degrees, lower your car (springs) if not already, and get subframe connectors for making chassis stronger. then get aftermarket headers/offroad x or h pipe, and dump at the mufflers.
anything else like H/C/I should be done together and require alot of supporting things. for example, cam will require stronger valve springs and u might think about going with 1.7 roller rockers at that point too. then u may need longer pushrods and taller head covers which may require a spacer for the intake to clear the covers. then there's piston to valveclearance to think about throughtout all this. for streetable performance noticability u will have to do this type of heads/cam/intake upgrades. or for upgrade noticibility which wont be all-time there, is NITROUS.
Old Feb 6, 2008 | 02:33 PM
euromay's Avatar
euromay
The first thing I would dois tolet your 5.0 breath starting with some BBK shorty headers, then an MAC off-Road H Pipe. Flowmasters mufflerswould sound amazing with this combo. The next step would be a set of Ford Racing 3.73 gears is a must. Then I would give it a performance tune up. The last thing I would addwould bea BBK cold air system with a K&N filter at the tip. This will make your car feel stronger with out droping a lot of cash!
Also, you could get rid of that crapy stock shifter and drop in a MGW Shifter to get the best out of your muscle.
TRUST ME, THIS IS A GREAT BEGINERS PACKAGE!
jtmustang's Avatar
jtmustang
ORIGINAL: 91hatchgt
that is so true but yes just like 91 said exhaust would be the first thing i did if i were u and then gears big difference just with the gears makes a stock car get up a lot quicker
Old Feb 7, 2008 | 07:10 AM
TexasJeff's Avatar
TexasJeff
Hey Guys thanks for all the great information, Dave93VertGT the car is an automatic. I do plan to do a MAJOR tune-up on the car to start with, maybe even add the MAF like maxwelhse suggested, some really easy and cheap to start with. From what you guys are telling me I think the exhaust will be next on the list, the car is a little to quiet for me now LOL. I have never done a rear end gear before I guess it is time to try. Again thanks for the information guys and I will keep y'all posted on my upgrades.
jwog666
Dec 27, 2021 08:09 PM
PaulH2
20
Jan 31, 2016 09:48 AM
mungodrums
Sep 28, 2015 10:54 PM
Sep 25, 2015 09:06 AM
