smog pump delete
Old Feb 6, 2008 | 11:09 PM
RedMachAndOrangeFox's Avatar
RedMachAndOrangeFox
Default RE: smog pump delete
i just used a shorter belt, i think a 730 was the measurement
Old Feb 7, 2008 | 12:08 AM
bighungrymatt's Avatar
bighungrymatt
part # 770k6 to keep the ac,ps and delete the smog(this belt keeps the stock routing)
I got mine at auto zone
Old Feb 7, 2008 | 01:31 PM
Hicompression's Avatar
Hicompression
ORIGINAL: Maxwelhse
I'll also add that as far as I've ever heard on here, I'm the only person that had a HUGE pain of a time getting those plugs threaded into the heads. If you're lucky, I'm the sole exception to the rule.
No...mine were a pain in the *** too. I used the "bolt as a tap" method. I saturated the threads of each hole with carb cleaner and used the correct thread size bolt to clean the threads of carbon kind of like a tap. It went like so...spray the threads with carb cleaner, turn the bolt in one thread, back it out, clean the carbon off the bolt, spray the hole again, screw the bolt in one more thread, back it out, clean the bolt with carb cleaner, spray the hole with carb cleaner, put the bolt back in the hole and thread it in one more thread...and on...and on...until the bolt threads all the way in up to the head. Took me a good hour each side.
Old Feb 7, 2008 | 01:40 PM
Maxwelhse's Avatar
Maxwelhse
You got lucky, I couldn't even start mine in the threads. [:@]
Old Feb 7, 2008 | 03:03 PM
stangbanger87's Avatar
stangbanger87
if you are running ud's i think the belt is 747k6 for ud's and770k6 for stock.
Old Feb 7, 2008 | 03:26 PM
Albizo66's Avatar
Albizo66
ORIGINAL: stangbanger87
i was just told by my buddy (hes a total mustang head) that my belt is too long, by about 1/2" to an inch..i have a/c delete and smog delete, with just the delete pulleys in the respecful spots..i also have underdrive pulleys..i have the stock belt size on now, and its too big
so will the 747k6 be what i need? on autozones website it says "Application: Without A/C"
Old Feb 7, 2008 | 03:50 PM
drhoward's Avatar
drhoward
Penis Mod Erator
its much easier just to swap on heads that are not smog legal
Old Feb 7, 2008 | 06:03 PM
95greengt's Avatar
95greengt
yeah but if i go that deep into the motor now i might as well go ahead and geta new upper and lower intake and a cam but dont wanna spend that much right now so ill probly just stick with the delete for now thanx though
Old Feb 7, 2008 | 06:27 PM
Maxwelhse's Avatar
Maxwelhse
ORIGINAL: drhoward
You are THE MAN if you can swap heads in 2 hours.
Old Feb 7, 2008 | 07:00 PM
95greengt's Avatar
95greengt
LOL[sm=hail.gif]
