smog pump delete
Old Feb 7, 2008 | 07:22 PM
  #21
stangbanger87's Avatar
stangbanger87
Default RE: smog pump delete
i think you would need the 770k6
Old Feb 7, 2008 | 09:12 PM
  #22
AdderMk2's Avatar
AdderMk2
Banned
you fox guys are impossible!!!
if you bypass the A/C AND the smog, you will need a 805k6
if you keep the A/C, you need a 885k6
Old Feb 7, 2008 | 09:13 PM
  #23
Albizo66's Avatar
Albizo66
adder i have them both bypassed, but pulleys in their spot, and underdrive pullies, what belt do i need?
Old Feb 7, 2008 | 09:19 PM
  #24
AdderMk2's Avatar
AdderMk2
Banned
ORIGINAL: Albizo66
ask a fox guy... the setup is different between a fox and SN
Old Feb 7, 2008 | 09:20 PM
  #25
Albizo66's Avatar
Albizo66
ORIGINAL: AdderMk2
ORIGINAL: Albizo66
dammit i forgot bout that
Old Feb 7, 2008 | 09:49 PM
  #26
Maxwelhse's Avatar
Maxwelhse
I could be 100% stupid on this, but don't underdrive pullies have a larger crank pulley and smaller accessory pullies (or vice versa)? Wouldn't that allow you to keep the same belt? I got curious, so I just looked through everything I could find from FRPP, March, and BBK and none of them specify what size belt to use.
Old Feb 8, 2008 | 08:49 AM
  #27
90_Mustang_GT's Avatar
90_Mustang_GT
I deleted my smog, and a/c. Moved my power steering pump up in the place of the a/c. I ended up with a 73.5" belt. Best way to do it is just cut your old belt or get a piece of string and run the route mark it and go buy a few belts around that length and take back the ones that dont work.
Old Feb 8, 2008 | 05:00 PM
  #28
95greengt's Avatar
95greengt
probly gonna keep the a/c for now (until it stops workin) but thanx everyone for the info
Bokeo
Oct 10, 2015 08:28 PM
Boostaddict
Lethal Performance
Oct 1, 2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
Oct 1, 2015 08:57 AM
Teddi
Sep 29, 2015 12:24 PM
