GREWSOME FOXBODY IGNITION DISCOVERY
RE: GREWSOME FOXBODY IGNITION DISCOVERY
i dont know if i understand what you're doing....
can you illustrate it or maybe explain a little more in detail. i've already dealt once with the TFI going out and i dont want to do it again...its annoying[:@].
ORIGINAL: FivePointOhh
mounting the module against the distributor makes the disty work like a heatsink
the problem with that is.. the distributor gets hot from engine temps, and negates any cooling effects the aluminum housing would have on the module.
the bottom line here is that it should not be done by the average person. the wires would have to be stripped, cleaned and soldered. Butt connectors will just not work here, I also think its a bad idea to simply "stick connectors into the distributor"
what do you suggest then? i'm actually really proficient at wiring(took a 2 years of electronics, one in highschool and another in college.) so i'm not your average joe for wiring, but if i do this i want to do it right. i hate it when that thing get heat soaked
as there a way i can deffer how long it takes before the unit burns up?
Adder, this was not my discovery. By the way, what do you use to polish your football helmet in your closet?
bradleyb
11-27-2015 07:50 PM
jessicarabbit
09-25-2015 12:41 PM
