window motor help?
Old Feb 17, 2008 | 01:34 PM
pk222's Avatar
pk222
Default window motor help?
hey, my window motor fried and I can't get the motor withen a couple days. My windows stuck down. What can I do to put the window up?
And any trick to getting the motor in there?
Old Feb 17, 2008 | 10:11 PM
lxman1's Avatar
lxman1
Default RE: window motor help?
If it's never been replaced, look for 3 dimples in the door frame in front of the 3 bolts that hold the window motor on. Drill them out so that you can put either a 5/16 or 8mm socket theu the frame. The loosen the 3 bolts enough to move the motor back away from the regulator enough that the gears do not touch and you can push the window up manually. Once the window is up, you can tighten the motor back down and this should hold the window closed.
Is the motor not working or does it run and not move the window? You can get a gear kit for about $25 and just reploce the 2 drive gears if the motor works.
Old Feb 18, 2008 | 12:21 AM
scooterstang's Avatar
scooterstang
I just had to take my motor out and after i drilled the rivets out i pulled the window up by hand and then put a hose clamp just underneath it on the bar in the middle and its done fine
Old Feb 18, 2008 | 11:22 AM
ponyponer's Avatar
ponyponer
my switches all went one by one. first the passenger side, and then the drivers side passenger switch, and finally the drivers side window. to get the passenger side one down or up i had to press the button for it on the drivers side, and the passenger had to pull down on it or up while the passenger pulled down. it was amusing.
Old Feb 18, 2008 | 03:43 PM
stang8689's Avatar
stang8689
Hit the motor with a hammer
Old Feb 18, 2008 | 09:44 PM
pk222's Avatar
pk222
I took my panel off and looked at it for a while and moved around some wires then tried it again and it brought it up half way and i pulled it up as I pressed the button, so its up now. I found one of the reasons it fried, the molding on the back of the window was halfway inbetween the inside and outside of the window and it was making a lot of drag.
Before it half way went out itd been going slow but never actually stopped working, It still works but I'm not trying to put the window down or up because I dont want it stuck down.
are these signs that i need a new motor or I've heard of clips or something that go bad that you could replace, does anyone know if it could be that ?
Old Feb 19, 2008 | 09:33 PM
stang8689's Avatar
stang8689
sounds like a weak motor
Old Feb 19, 2008 | 10:07 PM
scooterstang
get a new motor. its not like there is a whole lot to these windows. basically only your switch could go bad, but you said you used the switch. The arms could get stuck, just re grease them, and your motor, which you need to replace. And don't forget to grease everything while your in there
cr620
Oct 3, 2022 10:18 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
UrS4
Oct 3, 2015 06:23 AM
Explosive
Oct 2, 2015 07:45 AM
logan409
Sep 26, 2015 07:43 PM
