Problems with my 5.0
Old Feb 22, 2008 | 04:58 PM
jeffp10's Avatar
jeffp10
Default Problems with my 5.0
Alright I posted this on here a while ago then forgot my password. I am starting to work on my 5.0 again and would appreciate some help.
Last year i missed 4th gear with nitrous going and the car backfired verrrry badly. I know I am stupid for not running a rpm window switch.
the car would run ok for normal driving, but WOT/nitrous would not go very well. The car would backfire and cut out.
Now the car cuts out all the time. It bucks/jerks and never runs ok.
The first time I messed it up I checked the compression and it was good. I changed the plugs as well and those were good. I have been told i probably bent a valve and now it runs very bad all the time because the valve might have broken off.
What do you think?
Old Feb 22, 2008 | 08:09 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
Default RE: Problems with my 5.0
if it bent a valve a compression test will pick it up or a cylinder leakage test will confirm that.......if it runs bad could have a blown intake gasket..upper and or lower..and if it's got a miss I'd perform a cylinder balance test via the ecm self test function to find a cylinder which is contributing less power
Old Feb 22, 2008 | 09:47 PM
jeffp10's Avatar
jeffp10
Alright I will do both of those... Anyone know where i can get the upper to lower gasket for the BBK intake mani? I can't seem to find one anywhere.
What do i need to perform the cylinder balance test? I've never even heard of that.
Old Feb 22, 2008 | 09:56 PM
grabbem88's Avatar
grabbem88
koer test would work..
lower intake probably did blow.
you can also do a vac test and see what it is...it can tell alot
pop valve covers too check push rods/rockers/springs
Old Feb 22, 2008 | 09:57 PM
spence221's Avatar
spence221
hey you will have to have an OBD 1 scanner or know someone who does. i think advanced auto or auto zone have the scanners you can use or rent however they do it but i hope that helps!
Old Feb 22, 2008 | 11:44 PM
dimebag's Avatar
dimebag
no, you wont... a test light and paper clip work just fine
Granatelli Sales
Mar 25, 2016 08:01 PM
Granatelli Sales
Dec 27, 2015 06:28 PM
JT76
Sep 20, 2015 11:32 AM
vintageaion
Sep 8, 2015 10:45 AM
5.0 kevo
Sep 3, 2015 06:24 PM
