smog pump bypass
Old Feb 23, 2008 | 11:39 AM
stealth_lx's Avatar
stealth_lx
Default smog pump bypass
i am trying to by pass the smog pump. and was wandering if i could do this without using the bypass kit. any help would be greatly appreciated. i looked in FAQs and couldnt find anyting on this. thanks again david.
Old Feb 23, 2008 | 12:09 PM
ctgreddy's Avatar
ctgreddy
Default RE: smog pump bypass
you can, just disconnect everything and plug everything that its connected to.
for a clean look try and follow all the hoses and stuff back to the source and plug it there.
that way you dont have hoses running around with bolts in the end of them.
see if someone can tell you the belt size that works, i had to get the pulley cause i couldnt find a belt at my autozone that worked without squeeling.
Old Feb 23, 2008 | 08:37 PM
stangbanger87's Avatar
stangbanger87
duralast belt number 770k6 to bypass the smog pump.
Old Feb 23, 2008 | 08:41 PM
94Yellow50's Avatar
94Yellow50
sometimes it sucks living not to close to a autoparts store..i routed mine different than most usually do..so mine was a different lenght n i went to the parts store in two different towns like twice to the one n 3 times to the other cuz the size was being stupid...but if finally got it figured out....cant remember the size..but im goin to see my car for the first time in acouple months tomorrow ..so ill check n see what was..
Old Feb 23, 2008 | 08:52 PM
stang8689's Avatar
stang8689
just get the shorter belt
Old Feb 26, 2008 | 01:32 PM
stealth_lx's Avatar
stealth_lx
thanks for the belt number fits good but it looks like it is rubbing havent checked it to see what it looks like now that it is installed. just installed it yesterday. thanks for the help
Old Feb 26, 2008 | 02:59 PM
stangbanger87
no problem we all don't know everything right off the rip just look at some of my old threads and new ones i am still asking q's about fox rods .
jwog666
Dec 27, 2021 08:09 PM
Bokeo
Oct 10, 2015 08:28 PM
1996cobraconvertible
SVT Forums
Sep 30, 2015 02:01 PM
Teddi
Sep 29, 2015 12:24 PM
mrappe
Sep 26, 2015 10:16 AM
