will the MACH 1000 fit?
RE: will the MACH 1000 fit?
Anything will fit, just a matter of your craftsmanship abilities. I honestly cant tell you more than that because I dont have a fox, but in my experience with sound systems, you can make anything fit, and the uniqueness off your techniques add character.
I put a mach 460 in a fox before at work. It was fun finding a location for the amps but in the end you couldnt even tell that there was a different system in it. I put the Tweeters in the factory 3.5" location in the dash. Cut the door skins out and fiberglassed my own speaker grills. In the rear I had to fiberglass my own enclosure to go under the rear deck (fun times here) and use a TON of dynamat. It sounded pretty decent but I wouldn't do it again. I did it in a 93 coupe.
if i put regular like eclipse speakers in the dash, doors and rears would i even need to mount the tweeters? the system that i may buy only has the subs and the amps. id have to get a headunit seperate but i wasent planning on buying thespeakers or the tweeters.
my 93 had a audiobahn 6 speaker component system, 3-1/2" in the dash, 6" in the doors, and 6X9" in the hatch with a 2000w rockford amp pushin 2, 12's.
it sounded the *****, no tweeters. speakers ran off the panasonic headunit, 20w X 4.
what i would have would only be the 6 amps in the hatch and 2 subs and the headunit. i will possibly be putting JBL speakers in the car and i believe they have tweeters in them, would i need the tweeters from the MACH 1000 also?
jwog666
12-27-2021 08:09 PM
breaking
10-02-2015 01:27 PM
