new idle issues
Old Mar 22, 2008 | 12:34 AM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: new idle issues
Pull the vacuum line off the fuel regulator and make sure there isn't gas in the hose. You may also have a leaking injector which would cause both an idle issue and a rich condition.
dirty white's Avatar
dirty white
it is fuel injected with no maf im told they didnt start with maf untill 88 or 89
Old Mar 22, 2008 | 12:37 AM
dirty white
regulater test ok but may be injectors as they are original. if i replace them wich it probly needs anyway, think i should go bak stock or higher psi?
Old Mar 22, 2008 | 12:48 AM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
If the car is stock, stick w/ the 19's. Try pulling the plugs to see if it's 1 cylinder or more. Have you checked it for codes? Are you sure there are NO vacuum leaks.
Old Mar 22, 2008 | 01:04 AM
dirty white
havnt cheked for codes bought a reader but havnt figured out how to use it yet. dont think thers any vacuum leaks tho. the car has a chek engine light but it never comes on even wen the sensors were disconnected . wat dous it take to make the light come on? i have a 95 cobra 5.0 it is stok. if i were to put this motor in my car would it make any real difference? wat is the diff between the regular HO and the cobra HO?
Old Mar 22, 2008 | 01:09 AM
officer4c13's Avatar
officer4c13
the cobra has more power.
Old Apr 1, 2008 | 09:58 PM
dirty white
i am still trying to hunt my idle problums my car kills now every time i start it. how should i go about adjusting the throttle stop skrew?
Old Apr 2, 2008 | 04:51 AM
officer4c13
i would keep the screw were it is and try to find the couse to the problem. what all have you looked at trying to fix it?
Old Apr 2, 2008 | 06:59 AM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Have you taken the IAC off and tried cleaning that yet?
Old Apr 3, 2008 | 12:22 AM
dirty white
the iac is new i repleced it today. the reason i ask about the throttle stop is because a guy from down the road messed with it and i think he messed it up. dous anyone kno how this system accomplishes idle caus i think its on crak
