new idle issues
Old Mar 21, 2008 | 12:54 AM
dirty white's Avatar
dirty white
Default new idle issues
ok i re ran all the importan vacuum lines and reconnected the egr. this allong with adjusting the throttle stop screw wich was in way to far has improved driveability greatly also idles normally for the most part. the cam is stock also. still the car is running rich for some reason? if i leave it idling for a while it will throw blak soot on the ground also idling rough but at a steady rpm about 700-800rpm. wat can this 87 gt to run rich?
Old Mar 21, 2008 | 03:59 AM
officer4c13's Avatar
officer4c13
Default RE: new idle issues
o2 senser, maf,or other sensers. have it put on a coputer tester to check all the sensers.
Old Mar 21, 2008 | 11:44 PM
dirty white
car dousnt have maf. can i upgrade to this? would it idle better? car ran better today bt every time i stop it revs up to 2000rpm if i just tap the gas it comes bak down to about 800rpm. never done this befor. wat u guys think?
Old Mar 22, 2008 | 12:02 AM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Why was the egr disconnected and where did you run the vacuum line from to reconnect it?
Old Mar 22, 2008 | 12:11 AM
dirty white
th egr was disconnected becaus the mexicans i got the car from are idiots! i reconnected it to the egr controll switch on the right fender well the switch is connected to manifold vacuum.
Old Mar 22, 2008 | 12:14 AM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
OK, just makin sure it was hooked to the right source. Make sure it doesn't have vacuum at idle.
Old Mar 22, 2008 | 12:16 AM
officer4c13
if it an 87 isint it fuel injected?
dirty white
duznt and it idles the same if i pull the hose off.
Old Mar 22, 2008 | 12:18 AM
dirty white
it is fuel injected
Old Mar 22, 2008 | 12:31 AM
officer4c13
if it is fuel injected it should have a M.A.F. (mas air flow senser) it should be right by the inlet on you intake.
