wow royal purple!!!!!!!!
#31
RE: wow royal purple!!!!!!!!
ORIGINAL: 86GT 93LX
no thats their reg price:P i get the super tech fullsynth from them. it just stays cleaner longer.its supposedly made for them by mobile 1 so for 13 bucks its a good deal!
to the original poster, u just needed a oil change u wont notice a differance on a engine running reg clean oil. dump the royal and put in some cheap stuff u wont notcie a differance1 i swear! like mjr46 said 8hp, u cant feel 8 hp
ORIGINAL: 302army187
i dig castrol syntec!
the walmart by me must have messed up the price, becase a 5qt jug is only $19
(do the math, at $5.80 a qt, 5 qts is $29)
so i bought a few, and in about a mth ill put it in this car.
ive use it before in my old truck, and never gave me an issue, and for the price, for full sythetic oil.......... you cant beat it
think about this...
carbon is made from the combustion process right...
what cleans the motor and gets the carbon buildup out...the oil
if the oil holds the carbon and it comes out when you change the oil...then the oil did tis job (one of them)
clean oil means bad, esp if it has 3k miles on it.
synthetic blend is fine, "dino" oils are great, but rotella, redline, and amsoil are the only ones that make them. full synthetics are fine too. just dont flop back and forth from full synthetic to regular oil then back to full syn.
motorcraft full synthetic is good stuff (i work at a dealership, the ford gt uses 10qts of that pricy stuff)
in my stang, i did use rotella to break it in...then had thrust bearing failure. this time im just using mobile 1 untill i hit about 2k miles then i think im switching to a blend, but might just keep the regular oil.
#34
ORIGINAL: cleanfitty
A true synthetic is exactly that, on oil that is created in a lab and have nothing to do with crude. (ie Mobil 1, Amsoil, Redline, Royal Purple) Almost all others that claim themselves a 100% synthetic are typically not that. Their base is started out with crude oil that refined very well, then they add some other stuff and call it synthetic. (like castrol, super tech, valvoline,)
There are 2 variations of Castrol Syntec that are a true synthetic, and those are usually made in Germany or Europe. (Look on the back of the bottle and see where it is made) These are usually not common weights though.
If the stuff is made in the USA then it isn't a true "synthetic"
Also because of the Mobil 1 had a lawsuit against Castrol becasue of what they claim, and it was ruled that Castrol can put anything they want on the labels.
Do some research next time you try to come up with a bold statement of your own...
bold statement for no back up
unfortunately castrol syntc isn't a "true" synthetic.
#35
I'm pretty sure it is not made by them. Most Super Tech oils are made by Warren. And their filters are made by Champion Labs.
There is also a chance they low ball on who makes what for them, so it can change depending on who bids what.
ORIGINAL: 86GT 93LX
i get the super tech fullsynth from them... its supposedly made for them by mobil 1
yourmom6990
3.7L V6 Technical Discussions
10-14-2015 10:08 PM
