Wheel Comparison
Old Mar 23, 2008 | 03:00 PM
rust_stang's Avatar
rust_stang
I ♥ Acer
Default Wheel Comparison
Would these 2 wheels fit generally the same? one is 8" wide with 5.5" backspacing. The other is 7.5" wide with 5" backspacing. So if you do the math they should fit the same right? Just one has 6mm more offset.. which means?
PartComparison
function KBPopup(strUrl) {
var newWin = window.open(strUrl, "KnowledgeWin", "width=425,height=250,resizable=no,scrollbars=yes, toolbar=no");
Remove All
Brand
Weld Racing
Center Line Wheels
Product Line
Weld Racing Pro Star Wheels
Center Line Wheels Convo Pro Wheels
Part #
WLD-96-58210
CLL-005755445
Price
$179.95
$189.95
+ to Cart /Wish List
Description
Wheel, Pro Star, Aluminum, Polished, 15 in. x 8 in., 5 x 4.5 in. Bolt Circle, 5.5 in. Backspace, Each
Wheel, Convo Pro, Polished/ Natural, 15 in. x 7.5 in., 4 x 4.5 in. Bolt Circle, 5 in. Backspace, Each
Additional Info (
24[color=#000000]25 )
Additional Info
(8) This part is normally shipped directly from the manufacturer.
Backspacing (in)
5.500 in.
5.000 in.
Beadlock Functional
No
No
Beadlock Included
No
No
Center Bore Diameter (in)
3.180 in.
3.187 in.
Center Bore Diameter (mm)
Center Cap Included
Yes
Yes
Hub Centric
No
No
Load Rating (lbs)
Lug Nut Seat Style
Shank
Shank
Lug Nut Shank Diameter (in)
0.679-0.687 in.
0.679-0.687 in.
Lug Nut Shank Length (in)
1.300-1.380 in.
0.490-0.550 in.
Notes
The factory warranty will become void if used on any type of sports racing, road race, solo, 4WD, off-road, towing, vehicles exceeding 4,800 GVW, or the use of 31 in. or taller tires.
Offset (mm)
+25.00mm
+19.00mm
Quantity
Sold individually.
Sold individually.
Recommended Valve Stem
Rim Diameter (in)
15 in.
15 in.
Rim Width (in)
8.00 in.
7.50 in.
Valve Stem Finish
Valve Stem Material
Valve Stems Included
No
No
Washer Outside Diameter (in)
1.250 in.
Wheel Construction
2-piece
2-piece
Wheel Finish
Polished
Polished/Natural
Wheel Material
Aluminum
Aluminum
Old Mar 23, 2008 | 03:42 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: Wheel Comparison
They will be very close, either will fit you car. What do you think about these?
http://www.corral.net/forums/showthread.php?t=1005060
I almost bought these for my wifes vert but she decided she didn't want to run skinnies. The price is a steal!!!! Plus he's local to me and it would have been an easy purchase.
Old Mar 23, 2008 | 03:50 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
not a bad deal!! I paid 700.00 for mine with the skinnies and mt 275's on so 600 without is not that bad
Old Mar 23, 2008 | 04:26 PM
rust_stang's Avatar
rust_stang
I ♥ Acer
Very good dealand nice looking rims,I do already have 275 m/t's and skinnies.. I just need the rims. I know a guy here in the city that will give me a very good deal on any rims I want. Since my favorite rims are the convo pros I wanted to know if the 275's would fit w/ out sticking out of the fender.
Old Mar 23, 2008 | 05:56 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
I believe the convopros only come in a 5" backspace. W/ the 275's on them, they should be right at the edge but I don't believe they will stick out.
jwog666
Dec 27, 2021 08:09 PM
UrS4
Oct 3, 2015 06:23 AM
mungodrums
Sep 28, 2015 10:54 PM
folivier
Sep 26, 2015 02:28 PM
lincolnshibuya
Sep 24, 2015 10:46 PM
