need some help with the cluster
Old Mar 27, 2008 | 11:16 PM
yard248's Avatar
yard248
Default need some help with the cluster
I had this guy at florida5.0.com make me a dash to hold the auto meter guages. he said that due to clearance i have to go with the electric speedo. he said i can tap into the VSS to run my speedo. i have pulled my mechanical speedo cable back through the firewall. If i no longer need the mechanical cable, what should i do to fill the hole it leaves in the tranny. or do i have to have the mech cable hooked up in order for the VSS to work? also where is the VSS
1984 mustang 357W
Old Mar 28, 2008 | 04:27 PM
5.0stanger's Avatar
5.0stanger
Default RE: need some help with the cluster
If you car doesn't have cruise, you don't have a VSS. If you do have cruise, the VSS is located on the tranny where there speedo cable goes on at....the speedo cable goes on the VSS. You can get a VSS, plug it in to your tranny, go to ford and buy a pigtail, and wire it from there.
5.0muscle
Jan 11, 2016 01:17 PM
andrew1969
16
Jan 8, 2016 02:48 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
vash2810
Dec 31, 2004 01:56 AM
00GT00
Nov 23, 2004 02:15 AM
