air pump hose
air pump hose
so today i was doing some work on my ride as usual
the guy that owned it before me deleted the cats and had left the air hose there just cut opened
i had done some research and found that it needed to be welded shut
so i got out the old welder and put it back on and the car seemed to run a whole lot better
that is unless miraculously something else cured itself haha
RE: air pump hose
if your talking about the tube that runs to the back of the heads it should have a one way check valve built into it/ called an anti-backfire gulp valve but always good to cap it off
TfcCDR
09-14-2015 12:08 PM
