throttle issue
throttle issue
so my throttle has been pretty stiff latley. i am not quite sure what the problem is. when i press the gas pedal i must apply alot of pressure and then it pops, and sometimes theres no issues and it works fine.
RE: throttle issue
you most likely need a new cable as it may have worn though thee inner nylon protective sheath...fix it asap..cause if it pops one time and sticks......it'll throttle you right into the back of someone[&:]
09-08-2015 11:50 AM
zanemoseley
09-06-2015 12:58 PM
