Trick flow kit on 95 5.0- what problems?
Old Jun 8, 2008 | 01:49 PM
Bunk's Avatar
Bunk
Default Trick flow kit on 95 5.0- what problems?
So i am thinking about getting the trick flow head/cam intake kit for my 95 5.0 engine. Im scared of problems with the computer, The cam is just over .5 lift int and exh so i think the comp is gonna be lost.
What would be the best course of action here? Have the computer flashed? Any other options? In addition to the comp work i figure i will need some 24 lb injectors and the maf anf tb to match it.
Any links for advice would be appreciated.
Old Jun 8, 2008 | 02:06 PM
USMC1775's Avatar
USMC1775
Default RE: Trick flow kit on 95 5.0- what problems?
Any H/C/I swap will need to be dyno tuned for optimal performance and for the life of the engine itself
Old Jun 8, 2008 | 03:27 PM
5spd GT's Avatar
5spd GT
The trickflow valve covers may present a problem on a Sn-95. The camshaft will be okay. You will need need the upper intake adapter as well, that the fox does not have.
Old Jun 8, 2008 | 03:39 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
^^^^^nope the trick flow valve covers that come in the kit work fine......just need to grind a little on the egr mounting base and as for drivibility..you'll need a tune to correct any idle surge accompanied with cam .. if it were me to avoid a tune I would replace stage 1 cam with a steeda #19
Old Jun 8, 2008 | 09:03 PM
Bunk's Avatar
Bunk
Thanks MJR46. I would like to have a bit more agressive cam if possible, Are there any easy ways around this or would you still suggest the 19 cam?
Old Jun 8, 2008 | 09:08 PM
AdderMk2's Avatar
AdderMk2
Banned
I think the biggest problem you will have, will be the lack of power, and empty wallet
you can do alot better, for alot less money
Old Jun 8, 2008 | 09:26 PM
stang8689's Avatar
stang8689
AFR heads **** on trick flow
Old Jun 8, 2008 | 10:00 PM
mjr46's Avatar
mjr46
ORIGINAL: Bunk
I've put a few of those trick flow kits on sn-95's and I haven't been impressed with the power output vs cost.....adder's right.....a properly tuned gt-40 set up can yield you as much as the bolt on trick flow set up for a lot less money
Old Jun 8, 2008 | 10:14 PM
jtmustang's Avatar
jtmustang
oh here we go again ragging on trickflow even though they are the winningest head in the nmra and more ,but yes u can get close to the tricklow kit for a little less.
Old Jun 8, 2008 | 10:23 PM
5spd GT's Avatar
5spd GT
ORIGINAL: mjr46
Two things wrong with your post.
1) I did not say it would not work at all. I said it may present a problem, and you listed it.
2) You do not need a tune for a TFS-1. My buddy (1994) has a TFS-1 and no tune needed. Runs just fine.
