AC doesnt work, relay?
Old Jul 7, 2008 | 10:38 PM
Slo5oh's Avatar
Slo5oh
Banned
Default AC doesnt work, relay?
My ac was working, and then all the sudden it stopped after sitting for a few weeks. The compressor isnt seized, and there are no leaks, in fact the pressure in the system was at 120psi! yikes! I drained and refilled it with 134 but the compressor refuses to engauge. I was thinking its a relay or fuze of some sort. Anyone else have this issue?
Old Jul 8, 2008 | 09:33 AM
davidgt97's Avatar
davidgt97
Default RE: AC doesnt work, relay?
Sounds like a high pressure switch. I had the same thing happen on my 94. On my car it is close to the pass. firewall. Once you have located it pull the plug off of it and use a jumper wire to go from one side of the plug to the other. Check to see if your compressor is engaged and if it is your High Press. Switch is bad. A new one for my car was only $15. There is also a fuse but you'd have to check your manual.
Old Jul 8, 2008 | 10:54 AM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
ORIGINAL: davidgt97
That would be the low pressure switch and on the foxbody it's located on the accumulator.
To the o/p, was the car already converted for 134a or did you do that?
Old Jul 8, 2008 | 09:14 PM
Slo5oh's Avatar
Slo5oh
Banned
ORIGINAL: PRO50SC
ORIGINAL: davidgt97
I did that.
Old Jul 8, 2008 | 09:22 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
when the pressures equalize like at rest= a/c compressor not on120 is not bad ...temperature outside affects the relative pressure in an a/c system...and your car is equipped with an a/c cycling clutch switch...it could be the prob also
Old Jul 8, 2008 | 09:38 PM
Slo5oh's Avatar
Slo5oh
Banned
ORIGINAL: mjr46
I would assume thats what the issue is, since it worked for a while then stopped then came on for a stutter and died again. Any hints as to where that is?
Old Jul 8, 2008 | 10:01 PM
mjr46's Avatar
mjr46
it's the one on top of the accumulator they are talking about = low pressure switch..jump two wire together and see if clutch engauges..if it does = bad switch if not ..it may have a bad WOT relay
Old Jul 9, 2008 | 06:32 AM
Slo5oh's Avatar
Slo5oh
Banned
ORIGINAL: mjr46
and incase its a wot relay, what does wot mean in this instance?
Old Jul 9, 2008 | 07:01 AM
mjr46's Avatar
mjr46
Wide open throttle relay...in front of passanger shock tower towards the bottom ..might be on the apron beside tower too
Tivo304
Aug 28, 2023 12:19 PM
TimeLord101
Sep 4, 2015 09:27 AM
cbird1177711
Sep 3, 2015 08:43 PM
cbird1177711
Sep 2, 2015 04:12 PM
