valve cover question
Old Jul 22, 2008 | 03:42 PM
FuzzyDiceRule's Avatar
FuzzyDiceRule
Default valve cover question
i bought some ford racing black with brushed fins "mustang powered by ford" valve covers
im going to be using these with 1.7 ratio rockers
theyre short, i know to make em fit i have to take out the baffle, but both have three peices of the metal with holes to bolt the baffle to, if you understand what i mean, is all i have to do for proper clearance remove the baffle on the pass. side, or do i have to remove all of the rogue stallactites inside the covers too?
Old Jul 22, 2008 | 04:24 PM
ctgreddy's Avatar
ctgreddy
Default RE: valve cover question
Not sure with those but i have 1.6 ratio's and stock fox vc's with thick gaskets cleared mine just fine. So you might be able to leave the baffle's in and just get the thicker gaskets.
Old Jul 22, 2008 | 04:55 PM
FuzzyDiceRule
[&:]you dont need thicker gaskets to clear 1.6 ratio rockers, lol, thats the stock ratio
Old Jul 22, 2008 | 08:38 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
^^^sometimes you do! it all depends on the valve cover being used...in your case put some play dough on top of the rockers and set the covers on and measure the crush on the play dough and that'll answer your question
Old Jul 23, 2008 | 12:45 AM
FuzzyDiceRule
lol, fine, i guess i get to go next door and steal some from my neighbors kid [&:]
Old Jul 29, 2009 | 02:40 PM
paulfm5.0's Avatar
paulfm5.0
anyone have a thread saved on how to grind the 86-93 fox valve covers to fit over roller rockers? i'm curious to see how guys did this without removing the oil baffle
Old Jul 29, 2009 | 03:18 PM
AdderMk2's Avatar
AdderMk2
Banned
they dont need to be ground. I am running comp cams pro magnum roller rockers under a set of fox covers, all I did was remove the baffle plate by unscrewing it.
use the permadry blue valvecover gaskets too... they are thick and give more clearance
Tivo304
Aug 28, 2023 12:19 PM
bconboy
Sep 21, 2015 12:52 PM
zanemoseley
Sep 6, 2015 12:58 PM
aleit2013
Sep 4, 2015 11:58 AM
cbird1177711
Sep 2, 2015 08:51 PM
