Solid Engine Mounts?
Old Jul 23, 2008 | 11:18 AM
USMC1775's Avatar
USMC1775
Default Solid Engine Mounts?
What do you guys know? I was looking to replace mine since they have 140k on them nowfor when I do the engine swap
Old Jul 23, 2008 | 11:56 AM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
Default RE: Solid Engine Mounts?
if it's street driven....I'd use polyurethane ones
Old Jul 23, 2008 | 02:11 PM
5.0stanger's Avatar
5.0stanger
I like my solid ones...I can't even tell....
Old Jul 23, 2008 | 02:12 PM
uedlose's Avatar
uedlose
yea I can tell you from experience solids will let you feel every thing from the motor we had to use them when we put the turbo on my wife's car due to the down pipe hitting the poly mount we had on it before you will still feel more with the polysthen you would with the stock ones but it is not near as bad and they are much stronger. I also was reading where one guy that ran solids on a stock block with a high HP the block would flex and the freeze plugs would pop out after this happening 2 times they put back on a softer mount and the problem went away. just another testament of the stock block not taking big HP numbers
Nick Oliver
Oct 17, 2018 04:22 AM
bjdutch2005
Mar 24, 2017 03:38 AM
Nov 10, 2015 11:39 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
