carb help?
Old Jul 26, 2008 | 06:01 PM
cogman74's Avatar
cogman74
Default carb help?
ok so far i have learned alot, thanks every one. here we go again, found out my pistons were cooked so i need to replace them. i plan on getting a BG blow thru and get some dish pistons. some say i need to dyno some say i can tune carb my self. any feed back? i'm trying to build it with dyno tuning[eventually], and kind of old school uner hood?? also i found some one local who can rebalance the assembly, he said it should be a rocket. remember it is only a weekend car, maybe 4 times a month, probally no track time.
Old Jul 26, 2008 | 06:06 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
Default RE: carb help?
what's the whole set up??? turboed?? supercharged??
Old Jul 26, 2008 | 07:06 PM
cogman74's Avatar
cogman74
supercharged. 6lb or 9lb i'm not sure yet. it might make good enough power without the blower. its not to hard to covert i heard. ofcourse i will be getting plenty of help from some stang friends. by the way it being a 331 all forged roller motor,h-beams,ported windsor sr heads,hpipe,nuetral balanced,1.6 roller rockers,msd,tfs stage ll cam,equal length shorties,elec. fan,big rad. not sure about intake, think a weiand xcellorater, BG 575 BT carb. with a bigger carb, dual plane intake it shuold make much more power than a stock 302 ho with 6lbs of boost right.
Old Jul 26, 2008 | 11:31 PM
mjr46's Avatar
mjr46
do yourself a favor and if building a boosted motor put some dished pistons to lower compression...in the long run you'll get more out of the combo safely with lower compression
bradleyb
Nov 27, 2015 07:50 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
Sminemann
Sep 17, 2015 09:24 AM
Daddys Girls GTs
Sep 14, 2015 08:46 PM
jaiidutch
Sep 14, 2015 10:29 AM
