can it overheat???
Old Jul 24, 2008 | 06:49 PM
19MustangGT90's Avatar
19MustangGT90
Default can it overheat???
The temp gauge in the gauge panel wont move from 0after even when driving in 95 degree weather. How do i know the radiator is still working? what do i need to replace?
Old Jul 24, 2008 | 07:21 PM
ctgreddy's Avatar
ctgreddy
Default RE: can it overheat???
that sounds like a bad gauge or bad sending unit. go to autozone ask for a sending unit, u want the one with a little screw type thing coming from the top not a plug. its easy to change and cost about 12 bucks, if that dosen't work theres something messed up with the wiring.
Old Jul 24, 2008 | 09:36 PM
19MustangGT90
well does this mean that the cooling system wont work at all?
Old Jul 24, 2008 | 09:47 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
just because the gauge isn't working doesn't mean the cooling system isn't!! the gauge is seperate from cooling system it has no influence on whether or not the system works, try replacing sending unit and see if gauge will register
Old Jul 24, 2008 | 10:17 PM
65coupe88hatch's Avatar
65coupe88hatch
[&:] haha i have the same issue i just got a aftermarket gauge, after countless trys to figure it out, replace the sender, check for bad wire, came up with nothing im assuming my gauge cluster is bad.
Old Jul 25, 2008 | 05:34 AM
ctgreddy's Avatar
ctgreddy
ORIGINAL: 65coupe88hatch
thats another option you could get an msd gauge for 50 or could prolly go to autozone or something and get a sunpro gauge for less than that. and don't worry if ur car never overheated before than it should be fine. the system works just fine without the guage, i don't believe there's anything in the cooling system electrical wise that would cause it to stop working.
Old Jul 25, 2008 | 08:54 PM
19MustangGT90
where is the sending unit located?
Old Jul 26, 2008 | 11:35 AM
ctgreddy's Avatar
ctgreddy
it screws into the lower intake, to the right of the distributor. this is what it'll look like,
sending unit
should be a little black plug type thing on the top just pulls off, then put a socket on it and take it out but it may leak a little coolant so be ready.
Old Jul 26, 2008 | 11:32 PM
lxman1's Avatar
lxman1
Pull the wire off of it and use a piece of wire to ground the wire to the engine. If the gauge goes to full hot with the key on, then the sending unit is bad.
All the sending unit is, is a variable ground. The hotter it gets, the less resistance to ground and the needle goes up.
Daveyboy
Aug 4, 2006 04:29 AM
Mac 108
Jul 25, 2006 01:23 AM
ok_ee
Jun 27, 2006 08:27 AM
fastmfer
Sep 30, 2005 02:29 PM
camocreek
May 25, 2005 02:18 AM
