NEED HELP QUICK!
Old Aug 1, 2008 | 03:50 PM
1988GTstang's Avatar
1988GTstang
Default NEED HELP QUICK!
my fuel pump just went i have no money to pay sumbody how do u replace it? and how much of a pita is it? and wut size?
Old Aug 1, 2008 | 04:20 PM
FuzzyDiceRule's Avatar
FuzzyDiceRule
Default RE: NEED HELP QUICK!
its like 100 bucks for a new one, its pretty straight forward, the bitch is if your tank has any gas whatsoever, prepare to become combustable
basically, jack the back end up pretty high, undo the 4 bolts for the filler neck up by the filler under the car, put a jack or something to support the tank in place, undo the 2 bolts holding the straps in. After some finnessing which involves removing the filler neck from the tank, pull it out. Use a screwdriver to knock the retaining ring loose, pull out the assembly, put in the new pump, rewire, whatever you gotta do, and reverse the process
have help, its a bitch to do alone
Old Aug 1, 2008 | 04:25 PM
OnyxCobra's Avatar
OnyxCobra
Definitely have a person help you, worst job I've ever done on my car.
Along with the fuel pump it would be a good idea to buy a new lock ring and gasket along with the filler neck gasket, there's a good chance you'll screw it up taking it out and even if u don't it's good to replace it.
Old Aug 1, 2008 | 04:29 PM
ctgreddy's Avatar
ctgreddy
i did mine by myself and didn't replace anything but the pump, used the same lock ring, same gasket and ****. don't have any problems leaking or anything, just have a problem with teh car running haha. it took me like 2 hours to do it by myself, with 2 jacks, and all the necessary tools. but however don't use a screwdriver to knock out the lock ring, use a piece of wood or something brass cause otherwise you'll risk causeing a spark and spark plus gas isn't good.
Old Aug 1, 2008 | 04:37 PM
RODRIGUEZ's Avatar
RODRIGUEZ
ORIGINAL: FuzzyDiceRule
What do you mean by this?
Old Aug 1, 2008 | 04:38 PM
FuzzyDiceRule
yeah, i didnt hit the driver with a hammer or anything though, i just pushed it, lol, still probably not the best idea
Old Aug 1, 2008 | 04:53 PM
jtmustang's Avatar
jtmustang
easy job a new pumps around 100 bucks and i did mine myself with a 1/2 tank on about an hour and a half , but would be way easier with a buddy.
Old Aug 1, 2008 | 10:34 PM
1988GTstang
i got a friend a who will help me so wut tools are needed like socket size wise or is at all screwdrivers? and yea im not tryin to become a human torch so no sparks lol
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
svfetter
Oct 5, 2015 11:39 AM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
Sep 25, 2015 06:30 PM
