runnin rough!
Old Aug 20, 2008 | 09:40 PM
thrty5thsc's Avatar
thrty5thsc
Default runnin rough!
Whats up guys? I got an 86 GT and it's runnin rough, somtimes. It seems to sputter at red lights and at a steady speed. When I give it gas while driving it runs great. I put new plugs, wires cap and rotor. no change. also after driving when i put it in park it idles at 1100. Do you think it could be an injector that is dripping fuel?
Thanks alot.
Joe
Old Aug 20, 2008 | 09:56 PM
mustangsneverdie's Avatar
mustangsneverdie
does it have a vacuumm advance on it
Old Aug 20, 2008 | 10:24 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
run a koer test and check for codes, if that yields nothing look for vaccum leaks and make sure the egr isn't partially hanging open.
Old Aug 20, 2008 | 10:47 PM
thrty5thsc's Avatar
thrty5thsc
No vacuum advance. It's TFI.
Old Aug 20, 2008 | 10:49 PM
thrty5thsc's Avatar
thrty5thsc
I don't have any access to test equipment either.
Old Aug 20, 2008 | 10:53 PM
mustangsneverdie
just check for vacuumm leaks thats what it sounds like to me my car was acting like that a coupla days ago
Old Aug 20, 2008 | 10:55 PM
thrty5thsc's Avatar
thrty5thsc
I have the day off tomarow so i'll check.
Thanks alot. I'll let you know what I find.
Old Aug 21, 2008 | 09:49 AM
mjr46's Avatar
mjr46
using the koer test function perform a cylinder balance test and see if any code indicate where a misfire may be
Old Aug 21, 2008 | 10:26 PM
thrty5thsc's Avatar
thrty5thsc
Some vacuum lines look questionable. I bought some new lines but I ran out of time today. I'll update this weekend. I'm going to pull the upper plenum off and check for a leaky injector too. My concorde had a simillar problem that turned out to be a leaky injector.
Old Sep 3, 2008 | 11:15 PM
thrty5thsc's Avatar
thrty5thsc
changed almost all vacuum lines and no change in the way it runs. I tryed to get the 5.0 plate off the intake but I can't get the damn screws to crack loose? got any tricks for that?
Thanks!
GimpyHSHS
19
Dec 19, 2023 01:12 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
2007StangV6
Jan 28, 2016 06:09 PM
Ghost_Conscience
Sep 23, 2015 02:17 PM
TorinoCobra070
SVT Forums
Sep 18, 2015 10:34 AM
