help, im stumped (clutch)
Old Aug 23, 2008 | 04:25 PM
patrickfxck's Avatar
patrickfxck
Default help, im stumped (clutch)
so last winter i put a stock clutch cable on, and ever since its been slipping, so i took it to a tranny shop and they told me i have the "wrong parts" on the car(that half moon thing the clutch cable attatches to and another part right next to it by the gas pedal) sorry idk what their called. so i took off the half moon part and its a bbk part so i doubt its the "wrong part".
my guess is since i put a stock clutch cable on i need a stock half moon thing and maybe my clutch will stop slipping?
and another thing is i need to get that long shaft thats connected to the clutch pedal out, but theres a part on it i cant figure out how to get off, its really loose but i need to pull the shaft towards the drivers side to get it out, but the part is on the passenger side stuck on the shaft and i cant get it off, it was right next the half moon thing. i tried hitting the shaft towards the drivers side hoping it would just pop off but its not moving so if anybody has any ideas let me know.
heres a picture of the half moon thing.
http://www.bbkperformance.com/produc...stang-398x.jpg
Old Aug 23, 2008 | 05:12 PM
mustangsneverdie's Avatar
mustangsneverdie
do you have firewall adjuster for the cable
Old Aug 24, 2008 | 10:12 PM
patrickfxck
no do you think that would stop the slipping
Old Aug 24, 2008 | 10:43 PM
93 LX FiveO's Avatar
93 LX FiveO
where does the pedal grab?
should be atleast 1-1/2" off the floor
Old Aug 24, 2008 | 11:00 PM
mcfomco's Avatar
mcfomco
You need an adjustable cable or firewall adjuster and it will solve your problems.
Old Aug 24, 2008 | 11:10 PM
Jfsram's Avatar
Jfsram
If this suddenly happened after you swapped out the cable. Most likely you have the cable way too tight.
93 LX FiveO has pointed you in the right direction. The point of engagement should be off the carpet but way before the top. I think there is about 5 or 6 inches of travel. So half way is pretty good. If it is near the top, it's too tight.
Old Aug 24, 2008 | 11:16 PM
mcfomco's Avatar
mcfomco
The stock cable has no adjustment when the quadrant has been repalaced with a bbk. He need to get something to actually be able to adjust the cable. IE firewall adjuster or adjustable cable.
Old Aug 25, 2008 | 03:27 PM
patrickfxck
that makes sense because after i did the clutch cable it grabbs way far back, im not sure as to where off the ground but defintley a lot farther then it did. thanks guys youve been a big help im going to put a cable adjuster on and see how it goes
Thunderball
15
Nov 22, 2015 11:49 PM
junior04
Sep 28, 2015 10:53 AM
MacSerio
Sep 27, 2015 01:05 PM
stangin1996gt
Sep 21, 2015 11:01 AM
ccdguy
Sep 19, 2015 05:20 PM
