head lights need cleaning
one of two ways:
#1. == quickest, I get out my high speed buffer and rubbing compund and hit it good with that then go back with a fin cut cleaner and then a polish, all done with the high speed buffer, when done they will look good as new
#2, before doing number 1 step...wet sand it then buff, however if the right compounds are used in step 1 it often is not necessary to wet sand
1. Replace them
2. Do as mjr46 stated, yet this takes away the UV protection and there's a product out there that can reapply this protection or they slowly get yellow again....not sure what it's called.
3. Buy a four eye
3. Buy a four eye
if you have acess to auto clear you cna always wetsand and clear them
personally though if they are bad just buy a new set, and this time wax them every so often to ward off the suns effects
