Stalling...
Old Aug 29, 2008 | 04:52 PM
thedude's Avatar
thedude
Default Stalling...
My 5.0's acting strange. It started a year a go and has gotten dramatically worse over time. When I first start up the car, it can take nearly a minute for the rpms to settle just under a 1000. Before it settles the needle goes up and down and if I don't give the car a little gas it stalls. This also happens when I down shift to second whilst making turns. The rpms drop below 500 and the car stalls, which is not fun when people are turning behind me. Any thoughts. I thought it might be the tps but I don't really know. Other than this issue the car runs great the rest of the time.
Old Aug 29, 2008 | 09:43 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
run a koer test and check for codes, if none check for vaccum leaks, if none , could be a bad or dirty IAC motor
Old Aug 29, 2008 | 10:04 PM
AdderMk2's Avatar
AdderMk2
Banned
you need to do a base idle relearn, and clean your IAC.
worked wonders for my car
Old Aug 29, 2008 | 11:10 PM
z24stang's Avatar
z24stang
Do what the old boys said.Vacumme leaks,check codes,base idle reset,fresh tune up.Problems after that,then post up and help will come.GL.
Old Aug 30, 2008 | 11:14 AM
thedude's Avatar
thedude
Thanks. Will try these things.
Night Terror
Oct 20, 2008 09:11 PM
Shelty
Aug 21, 2008 12:18 AM
newownerof72
Sep 4, 2005 02:03 PM
