would this be possible
these these springs i bought on my e7 head wont work on the 289 head?
and if not...why not? i'm curious. seating pressure?
http://store.summitracing.com/partde...0&autoview=sku
well they cost 110 dollars to get them from the bone yard. then they have to be machined on top of that and potentially may give me less power. i already have these 289 heads(not 351), i dont have to search, search, search and then remove them from the vehicle when i find them finally. i already have the machining priced out by a friend at a machine shop here locally and its cheap
, a machine shop should be able to make things work or tell you if any extra work is needed to make them work, I'm just going offf of what I have run into in the past
when you spray that puppy coupled with the high rpm's and excessive cylinder pressures generated by NO2...if the springs aren't set up right a valve flutters open when it shouldn't you can expect one heck of a NO2 backfire and if large enough it can blow gaskets and even an intake off
i was comparing my springs vs the ones suggested for that cam for the hyd. roller.
my specs are seating pressue 110lbs and open pressue 240lbs
the ones recommended with that cam are seating pressure 121lbs and open 343lbs
are those differences very significant or not enough to matter? any problems with running my single spring?
i meant cheap as in a friend is doing them and isnt charging me a ton to do it. we've been friends for a long time so its not at regular shop rate. they'll be set up properly i guess im asking more on the grounds of i'd like to learn how and why things are done.
