I may have been duped! **Updated, good news**
09-18-2008, 05:32 PM
The Rogue Mod
Quote:
Originally Posted by
FivePointOhh
does your ring gear have product ID factory ID and gear ratio ID stamped on them?
No, they look like these they also have a #- 3L3-HB
09-18-2008, 05:37 PM
in limbo
my neighbor said they should have corrodinating numbers. i checked mine and sure enough they do.
my pinion is stamped 1L5LA-M7 and my ring has stamped on it 01-57
and both are stamped 373 on pinion and ring not written in like that other picture
09-18-2008, 05:40 PM
they are completely flat on the underside of the ring gear, like the above pic, if theres a 'groove' or cut along the outside edge they are motive like so...
09-18-2008, 05:42 PM
in limbo
mine are flat, no undercutting
09-18-2008, 05:44 PM
hey pro i put up that dyno sheet on the other post for you to take a look at
09-18-2008, 06:38 PM
Moderator
09-18-2008, 07:42 PM
look on the pinion gear lol
09-18-2008, 07:53 PM
Moderator
It doesn't say anything, the spot it was stamped is not legible.
09-18-2008, 07:59 PM
The Rogue Mod
09-18-2008, 08:33 PM
Moderator
PRO5.0, am I seeing things or is that a poorly stamped oval, it's the second pic you posted,
