Oil Pressure Issues
Old Sep 27, 2008 | 03:40 PM
83fox50's Avatar
83fox50
Default Oil Pressure Issues
I am completely stumped here.
so long story short, my mustang is leaking oil out the pan seal up front.
i went to replace the gasket (while still in the car), and i had to remove the oil pump to get the one piece in place. well now everything is back together, and not to my surprise it is still leaking, but after about half an hour of driving it the oil pressure started to drop, and now i get none. ran a primer tool on it for a while and it reads fine, but put the distributor back on and it cant sustain the pressure. pulled the pan again to make sure the pickup and pump were sealing and they are. what could be wrong with this thing? why wont it make pressure?
Old Sep 27, 2008 | 04:29 PM
Timspony's Avatar
Timspony
SVT Section Moderator
need to get a mechanical oil pressure gauge to test...
Old Sep 27, 2008 | 09:14 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
the oil pump to block has a gasket, did you put a new one in place??
Old Sep 27, 2008 | 10:26 PM
83fox50's Avatar
83fox50
of course i put a new gasket between the pump and the block i also put one between the pickup and the pump.
Old Sep 28, 2008 | 01:05 AM
RUDEDOG.357's Avatar
RUDEDOG.357
how many miles on your engine? maybe your main bearings are worn out. The oil leak is from the front oil pan gasket or the front crank seal? ck oil pressure with a gauge first before you do anything else.
Old Sep 30, 2008 | 09:15 AM
83fox50's Avatar
83fox50
well i forgot to mention that we hooked up my roommates Autometer gauge and sending unit to check if mine was bad. it was reading the same. my buddy thinks the tolerances in the oil pump and the spring might be bad.
i have no idea how many miles are on the engine, guy before me swapped a junkyard motor in. so we are replacing the whole pump and seeing if that fixes it.
if it does Bowling Green here i come.
Old Sep 30, 2008 | 11:28 AM
Timspony's Avatar
Timspony
Hope Bowling Green is not too far away!
Old Sep 30, 2008 | 01:04 PM
83fox50's Avatar
83fox50
its about 4.5 hrs away.
StalkerGT
Sep 25, 2015 02:41 PM
MusicCity615
Sep 12, 2015 07:05 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
kevsgt
Sep 9, 2015 06:20 AM
Sep 8, 2015 11:50 AM
