Would it be worth it....
Old Oct 1, 2008 | 04:05 PM
mustangsneverdie's Avatar
mustangsneverdie
I'm not sure because it came on my brothers 460 I think it's a 600 (not positive) with the vac secondaries.In the vid that I posted the other day at the end of 2nd you can hear it busting up
Old Oct 1, 2008 | 04:07 PM
mustangsneverdie
Originally Posted by FivePointOhh
you need, new fuel pump, fuel lines, fuel rails, fpr, injectors, intake, MAF, computer and full wire harness, all the sensors for efi and pig tails. you are looking into alot of work.
I've got the wiring harness and computer off an 89 vert still have the maf, sensors. I believe I have just about everything it's just gonna be awhile if I even do it
Old Oct 1, 2008 | 04:18 PM
USMC1775's Avatar
USMC1775
Its a carb off a 460? Is it a stock carb off a 460? If so, Id condemn that bitch in a hurry
Old Oct 1, 2008 | 05:39 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
if your carb has been running excessively rich then by now the plugs may be fouled which may account for the hesitation you now have,...you really should buy a carberator book and learn the theroy and operation, carbs are not that difficult and tuned right work well....but you need a good carb to start with not a used old worn out one that may have more issues than you know
Old Oct 1, 2008 | 06:09 PM
mustangsneverdie
the 650 had 64 size jets and the other carb had 66 jets I think if that helps any
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
treesloth
Sep 28, 2015 07:03 AM
fastbackford351
Convertible Tech
Sep 27, 2015 06:51 AM
2015Ecoboost
Sep 17, 2015 01:48 PM
showoffzx2
4 Cylinder NA and Turbo
Sep 14, 2015 08:40 PM
