Help with overcharging alternator.
Old Oct 8, 2008 | 03:26 PM
thajuggla's Avatar
thajuggla
Default Help with overcharging alternator.
87 Mustang 5.0 w/aftermarket radio, speakers, Viper 2 alarm and gauge pod.
Hey guys, I am having a small problem. This morning when I went to leave my house, I noticed that the AMP light was on and that my meter was reading at almost 18. I had my lights on and heat on because it was morning and cold, so the whole time I drove it was overcharging.
When I was on lunch, I started my car and revved it up to try to get it to overcharge but it wouldnt. Even turned on everything on that I had on in the morning to try and make it happen but it woudlnt.
So about an hour ago I left work and 15 minutes into the drive I notice Im overcharging again. This time I can control the overcharge by turning on my headlights or by turning on my heat full blast.
I left the car running when I got home and popped the hood to see if I could smell something grounding out, or some sort of sparky smell and I couldnt smell anything of the sorts. My horn, lights, interior lights, car alarm, radio, gauge displays, everything works. Nothing has shorted out, nothing is burning...
I checked the neg cable and its in perfect condition tight to the block... wtf is going on here? Thanks guys!
Old Oct 8, 2008 | 03:30 PM
kaggriff's Avatar
kaggriff
sounds like your voltage regulator is going out in the alt.
Old Oct 8, 2008 | 03:35 PM
thajuggla's Avatar
thajuggla
is that something theyd be able to see no matter what if i took it to the parts store, or does it have to be in the mood to mess up for them to see it?
Old Oct 8, 2008 | 03:38 PM
kaggriff's Avatar
kaggriff
they could check it. should show up when they put the system under a load. as your are describing by turn acc on and off.
Old Oct 8, 2008 | 03:40 PM
thajuggla's Avatar
thajuggla
Well actually when I had put the system under a load, I made the charge read normal instead of 17+.
On the way home it was like Headlights or Air on max = 12AMP?
No lights or air on = 17+AMP
Old Oct 8, 2008 | 03:44 PM
thajuggla's Avatar
thajuggla
oh and another wierd thing that happened is my left turn signal indicator on the dash never worked, so i figured it was a blown bulb. This morning after the overcharge, all of a sudden it works now.
Old Oct 8, 2008 | 03:52 PM
kaggriff's Avatar
kaggriff
sounds more like a short know that i understand it is backwards to what i thought. they can still test the system under a load and if the regulator or diode is going they should be able to pick it up and let you know with there equipment
Old Oct 8, 2008 | 04:03 PM
thajuggla's Avatar
thajuggla
ok cool man, thanks!
mirandaandjimmy
Nov 16, 2015 08:51 AM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
jjwinel78
Aug 17, 2015 03:34 PM
MAC67stang
Mar 30, 2006 06:42 PM
mysticsvtcobra96
Jan 15, 2005 11:08 AM
