harmonic balancer install
Old Nov 3, 2008 | 11:39 AM
SteveSkal's Avatar
SteveSkal
Originally Posted by camaroeater
Id park your car until you fix it. You don't want to kill the motor.
+1
You are putting undue stress on your main bearings if that balancer is wobbling, don't drive it anymore
Old Nov 3, 2008 | 07:29 PM
dillon1340's Avatar
dillon1340
Originally Posted by 94Yellow50
and when you remove the big bolt..make sure you remove the washer too..because ive read numerous times where people didnt and ended up breakin pullers...
i honestly can't tell you how many times i've done that. last weekend taking the balancer off my explorer i broke two pullers before i realized i was doing it again (man did i feel dumb, especially since it wasn't the first time). sometimes you can put a smaller bolt in the hole and push against that.
Old Nov 4, 2008 | 08:51 AM
cesloan's Avatar
cesloan
Originally Posted by mjcracing
it could be....i could look at the balancer while the car was running and see it wobble back and forth...the rubber bushing was also starting to come out
Took a look at the harm balancer and I don't see any "wobble". Any other way to test it?
A friend told me it could just be a "miss". I had a spark plug wire grounding out in my Expedition so I know what a "miss" feels and sounds like, since it does it from the lowest rpm up. This vibration is only above 1800 rpm.
Old Nov 9, 2008 | 09:39 AM
cesloan's Avatar
cesloan
Well, wasn't the harmonic balancer. I'm really stumped. Any way it could be the torque converter? The tranny is definitely ailing as it slips when you get on it.
Old Nov 9, 2008 | 06:23 PM
FuzzyDiceRule's Avatar
FuzzyDiceRule
hey dont even worry about the washer, just remember to put the litle cone shaped bushing on the end of the puller, i had mine thread into the snout of the crank of my friends engine..... i felt like an idiot, luckily we were getting a new crank anyway
but yeah, an impact wrench works nicely for the install
mtgldr
Feb 3, 2024 09:00 PM
BOBCATJACK
Sep 14, 2015 02:18 AM
Sep 10, 2015 08:39 PM
Sep 8, 2015 11:50 AM
