View Poll Results: oil weight
0w30
0%
5w30
5.71%
10w30
74.29%
10w40
5.71%
20w50
14.29%
Voters: 35. You may not vote on this poll
OIL
Old Nov 17, 2008 | 04:18 PM
kaggriff's Avatar
kaggriff
Default OIL
Just curious to what weight oil everyone is running. ARE you running sythetic or coventional
Old Nov 17, 2008 | 04:37 PM
Timspony's Avatar
Timspony
SVT Section Moderator
synthetic always ....5w30 in the '03 Cobra, 5w20 in the '05 GT & 10w30 in the 1991 GT!
Old Nov 17, 2008 | 04:39 PM
jzandy's Avatar
jzandy
i run 20/50 in my car during the summer. i dont drive mine in the winter but if you do i would change to a 10w30 or even a 5w. if you have an older vehicle the full synthetics will sometimes cause the car to start leaking at the seals so if you want to run synthetic i would look at getting the seals replaced .
Old Nov 17, 2008 | 04:56 PM
blkstng95's Avatar
blkstng95
10w 30 mobil 1 full synthetic
Old Nov 17, 2008 | 05:04 PM
kaggriff's Avatar
kaggriff
Originally Posted by jzandy
i run 20/50 in my car during the summer. i dont drive mine in the winter but if you do i would change to a 10w30 or even a 5w. if you have an older vehicle the full synthetics will not cause the car to start leaking at the seals so if you want to run synthetic i would NOT look at getting the seals replaced.
Yes indeed. I run full synthetic 10w30 year round was just curious as to what everyone else was doing
Old Nov 17, 2008 | 05:34 PM
crusin92red5.0's Avatar
crusin92red5.0
diddo
Old Nov 17, 2008 | 07:37 PM
ryan_89_mustang's Avatar
ryan_89_mustang
I run 4 quarts10w 30 mobil conventional and 1 quart of Lucas oil stabilizer
Old Nov 17, 2008 | 07:41 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
10w 30 amsoil synthetic high performance line
nseoi's Avatar
nseoi
5w30 Mobil 1 Synthetic in the 5.0 since i put in the crate last year. Every 1000ish miles because I'm obsessive.
Just started 5w30 Synthetic in the 2.3L Last oil change. I hope it goes well, the engine feels grate even tho its the original '92 engine.
Nothing but Mobil1 or Motorcraft filters too
Old Nov 17, 2008 | 07:56 PM
jzandy's Avatar
jzandy
mjr i really dont appreciate the edit because it sometimes does, and the reason I know this is because it just happened to my car with the rear main seal. i switched to synthetic and i started experiencing leaking at my seals. A ford racing specialist also informed me that a switch from convential to a full synthetic in an older vehicle could cause it to leak. so unless you are 100% positive don't go around edited peoples ****! thank you!
