fix wheel hop
11-29-2008, 11:07 PM
fix wheel hop
just installed new control arms and springs, now it has wheel hop really bad. how do i fix it.
11-29-2008, 11:13 PM
are the ca's adjustable? if so your pinion angle's prolly messed up and you need to adjust the ca's
11-29-2008, 11:23 PM
ya the same thing happened when i changed mine lol, another thing to look at is your upper control arm bushings on the pumkin.
11-29-2008, 11:42 PM
re
no they are not. should i put the quad shocks on?
11-30-2008, 09:13 AM
M.A.D. Motorsports
Cheaper arms will cause wheel hop from what I have seen. Are they the summit ones in your sig? If so I almost guarantee that is why you have wheel hop. That is one place that I am not gona skimp on when it comes to replacing mine.
11-30-2008, 10:32 AM
Try replacing the quads, or if you didnt during the swap, like said before, replace the upper bushings on top of the diff
11-30-2008, 12:37 PM
re
thanks, the quads aren't on right now. i'll put them on and see what happens. i have some bushings on the way. i'll keep you posted.
Tivo304
08-28-2023 12:19 PM
mmarsh3014
Wheels & Tires
10-20-2015 09:08 AM
67LimeCoupe
09-30-2015 04:46 PM
zanemoseley
09-06-2015 12:58 PM
