fix wheel hop
Old 11-29-2008, 11:07 PM
87slutstang
87slutstang's Avatar
Default fix wheel hop
just installed new control arms and springs, now it has wheel hop really bad. how do i fix it.
87slutstang is offline
Old 11-29-2008, 11:13 PM
ctgreddy
ctgreddy's Avatar
are the ca's adjustable? if so your pinion angle's prolly messed up and you need to adjust the ca's
ctgreddy is offline
Old 11-29-2008, 11:23 PM
kweb288
kweb288's Avatar
ya the same thing happened when i changed mine lol, another thing to look at is your upper control arm bushings on the pumkin.
kweb288 is offline
Old 11-29-2008, 11:42 PM
87slutstang
Default re
no they are not. should i put the quad shocks on?
Old 11-30-2008, 09:13 AM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
Cheaper arms will cause wheel hop from what I have seen. Are they the summit ones in your sig? If so I almost guarantee that is why you have wheel hop. That is one place that I am not gona skimp on when it comes to replacing mine.
projectresto83 is offline
Old 11-30-2008, 10:32 AM
USMC1775
USMC1775's Avatar
Try replacing the quads, or if you didnt during the swap, like said before, replace the upper bushings on top of the diff
USMC1775 is offline
Old 11-30-2008, 12:37 PM
87slutstang
Default re
thanks, the quads aren't on right now. i'll put them on and see what happens. i have some bushings on the way. i'll keep you posted.
Tivo304
08-28-2023 12:19 PM
mmarsh3014
Wheels & Tires
10-20-2015 09:08 AM
67LimeCoupe
09-30-2015 04:46 PM
zanemoseley
09-06-2015 12:58 PM
Quick Reply: fix wheel hop
