Help me out guys
Help me out guys
ok so just got done with installing the gt-40 explore intake. Heres what i did, seeing all my smog and everyting is deleted i took off the egr, i just made a block plate to go over. i didnt cut the connector, dont know if you have to or not.
As far as the vac lines in the back i have on hooked up to the vac tree as normal. One hooked up to the pcv valve, and the other hooked up to the fuel pressure regulator. i capped the others the best i could and i dont hear a vac leak, but my problem is the car kinda feels weak and i have a bad buck at low rpms.
I did check and adjust timing to 13*
