Full bolt ons before or after H/C/I
+1 i lost close 3 tenth with aluminum under drives. i got them used for 50
uh ok we're lying and dont have anything better else to do
anyways...it gave me 2 tenths...not only on my current coupe but my 90 gt i had...two different cars and each gave me 2 tenths...
it gave my 93 lightning 4 tenths...take that to the bank!
it gave my 03 mach 1 absolutely NOTHING...
Its got a header back flow master set up, dual cats. So ill be ditching the catted mid pipe for a O/R h-pipe. And BBK long tubes.
My biggest concern is the c5 tranny that is in it. I have no idea what kind of power it can withstand. Found just about zero about it by searching the web.
Rear end is fresh, gears, ive got drag radials, just did plugs cap wires ect...
ditch the c5 tranny and pick up a c4...you can get them cheap...i'd spend my money on that first before anything else....c4, stall convertor, good shift kit...
does your tranny have a D with a circle around it on the shifter?? if so it's an AOD not c-5, c-5's were 3 speeds and used in such things as v-6 bronco's and were not placed behing 5.0's, you would of had a c-4 if it were a 3 speed and there originally from factory.
breaking
Oct 2, 2015 01:27 PM
junior04
Sep 28, 2015 10:53 AM
