How does it compare?
Ok guys,
I've been trying to find comparison flow numbers or something about the Tubular GT40 intake manifold! I absolutely LOVE the looks of it, but what would I need to do for install? (any special parts?) I'm thinkin as long as I buy it with the lower and upper intake it would fit... Correct?
Would I be better off to just get the edelbrock rpm II? or would the tubular gt40 perform similar?
Ok guys,
Well I know the lower GT40 intake is the same as the cobra, explorer intake. I would think the gt40 upper would be better than the cobra but I dont know. The cobra intake is pretty close to the edelbrock intake. Here is some flow data
http://www.geocities.com/MotorCity/F.../Explorer.html
http://www.allfordmustangs.com/Detailed/614.shtml
I just found a site with gt40 flow numbers.
http://www.crt-performance.com/techtips2.htm
^There is some really good info on that site.
There is some conflicting data on those sites but for the most part there are fairly close.
sweet! thanks, great info! I was also wondering could I set up a different lower intake with the tubular upper? cuz (correct me if i'm wrong) the lower intake is more important, flow wise, than than the upper? so, could I somehow match a better lower to the upper to create better flow? I may be totally crazy for thinkin that, i'm just curious!
ya... I'm eventually going to have to get a new hood anyways... so hopefully i'll get all of it around the same time! Would you think that the tubular would perform significantly worse then, let's say the edelbrock RPM II? or would there only be a minimal difference?
I think the tubular would be a good intake but the explorer intake is pretty good for the price you find them. Edelbrock makes some fine products but it all depends in your combination. I doubt that there would be whole of hp difference in those intakes.
ok ya that's what I was thinkin... I'm buildin a 331 stroker should be done Jan 1st so hopefully once that's paid off I can get into more serious decision making! thanks for the help!
If you learn anything more! feel free to send me more info!
