disapointing HCI build.
Old Dec 28, 2008 | 05:58 PM
Portmaster's Avatar
Portmaster
Get those 1 5/8 shorty headers off that thing and it will pick up another 50 hp. The exhaust ports in those Pro-Comp heads are huge. The poor motor can't breath. It's like the air is trying to run the 100 yard dash through submarine doors.
Old Dec 28, 2008 | 06:08 PM
BlessedHellride's Avatar
BlessedHellride
My exhaust ports are big on my 190cc heads. I haven't had a problem out of them at all as of yet and probably won't. I have heard so many horror stories from internet forums about Pro Comp heads, I was scared about my heads. I had already bought them by the time I read all the bad news about them. But I must of gotten extremely lucky because I didn't have all of the casting flaws that I have seen in person on 3 sets of BBC heads and pictures on the forums. I just ran mine as casted, kinda wished I would of ported them now, but I wanted to see what I could get out of them like they was out of the box. I haven't weighed my car yet, but with my E.T. at the track, I figure I'm around 375rwhp. Like everyone else, I'm looking for more. I will bump my timing up a few more degrees before I take it to the track next time. It's set so low it's almost sickening.
Old Dec 28, 2008 | 06:20 PM
woodsy's Avatar
woodsy
NEVER picking up 50 with an 1-3/4, the head has serious flaws
Old Dec 28, 2008 | 06:34 PM
Portmaster's Avatar
Portmaster
No doubt it has some serious flaws. The engine cant scavange the exhaust if it can't get past those big ledges at the header flange. The engine has to exhale as well as inhale. You can't fill a cylinder with a good charge if you still half the dead charge backed up in the cylinder. Things like that can cost you some big hp.
Old Dec 28, 2008 | 06:44 PM
FivePointOhh's Avatar
FivePointOhh
in limbo
or maybe they are just crappy heads
Old Dec 28, 2008 | 06:48 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
just get a whole different h/c/i
Old Dec 28, 2008 | 06:53 PM
Portmaster's Avatar
Portmaster
I don't like the heads, wouldn't have a set of them. But even AFR heads won't breath if you block the exhaust ports. Even cheap parts can make good power somtimes. It's easy to speculate by blaming the crappist thing on the build. I see an obvious problem that I would have addressed first in that swap before I came to the conclusion that the heads caused the big problem with that car. It's like seeing a plug wire off and still blame the heads
Old Dec 28, 2008 | 06:55 PM
Portmaster's Avatar
Portmaster
for sure, I wouldn't have wasted my time putting any of that crap on
Old Dec 28, 2008 | 07:45 PM
FivePointOhh
in limbo
lol, im gonna try to make my crappy intake perform(typhoon). its all ported out, so when my heads and cam go in late winter early spring...hopefully she rips off some good ET's
Old Dec 28, 2008 | 07:53 PM
luckythirteen13's Avatar
luckythirteen13
the intake is the only half decent part they used. acutally the typhoon intake is pretty good. ports are large, just need to be cleaned up some. i made 461rwhp with the stock cam and that intake
