347 stroker cam help
Old Jan 5, 2009 | 06:31 PM
Deathbykarni's Avatar
Deathbykarni
Default 347 stroker cam help
ok to start off, im wondering what you guys think i should go with, i have a 95 5.0 motor, it has a trickflow upper/lower intake manifold, Edelbrock performer heads 170cc intake runners and 60cc cumbustion chambers, and the springs are good up to a .575 lift i believe, also it has a 347 stroker kit, Eagle Forged Crankshaft, Mahle Forged Pistons, And Eagle forged Connecting Rods, And A Full MSD Ignition system, Mostly everything else is stock and ive been looking around at parts but i have no idea what to go with, Im trying to find a Cam i wanna go with a hydro roller cam, and i need to find a nice cam, lifters, rockers, double roller timing chain, and other parts i need to go along with the cam, also im trying to find a 4 bolt main set up, a nice stud girdle and any other parts i may need, once the motor is done im planning on spraying a 250 shot into it, so any help you guys can offer is appriciated, thanks...
Old Jan 5, 2009 | 07:02 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
I'd use a better set of heads and intake..first
Old Jan 5, 2009 | 07:06 PM
cammedlx's Avatar
cammedlx
Agreed...Performer heads are barley big enough for a stock bottom end 302..Much less a stroker but there is no replacment for a custom grind IMHO.But comps XFI cams are good for off the shelf cams..And a 2 fifty shot on a stock block........BOOM is all i can say..
Old Jan 5, 2009 | 07:15 PM
Deathbykarni
yea, i have been looking for atleast a 210cc head, but whats wrong with the trickflow upper/lower intakes?
Old Jan 5, 2009 | 07:19 PM
cammedlx's Avatar
cammedlx
If its the street heat there a little on the restrictive side for a stroker..But the track heat and r series are good intake's Imo..
GimpyHSHS
19
Dec 19, 2023 01:12 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
EASTIDEE123
Sep 14, 2015 03:52 PM
