cold weather mpgs...
Old Jan 23, 2009 | 05:25 PM
OnyxCobra's Avatar
OnyxCobra
No biggie man all cars use more gas when it's cold outside.
Old Jan 24, 2009 | 01:07 AM
ctgreddy's Avatar
ctgreddy
yeah its very normal. until it gets close to operating temp its going to run pig rich to try and warm it up. and the winter mix fuel is also less effective.
Old Jan 24, 2009 | 10:06 AM
FORD TOUGH's Avatar
FORD TOUGH
Originally Posted by Shelty
I hate this ethanol crap... dumbest idea imo... "hey lets add something to the gas that makes it less efficient...
my roommate hates the stuff worse.. his '68 camaro with 80K on it... runs like crap with this ethanol stuff... (its an all original 327, only thing thats been changed on it was the plugs wires and it got a new dizzy some time in the '80s...
at least that only sees maybe 1-2000 miles a year
Believe it or not you make more hp with e85 but I doubt this e10 does much. Ethanol burns faster like alcohol. 5.0 mustang mag made switched a mustang over so it would run on e85 and the car made 6 hp more. Its not worth it for the mpgs you loose.
Old Jan 24, 2009 | 11:21 AM
ctgreddy's Avatar
ctgreddy
you should be able to make more of a gain then that. ethanol is anywhere from 100-105 octane, and its cheaper than 87. with that much more octane you should be able to crank up the boost or timing enough to get more than 6 hp.
Old Jan 24, 2009 | 12:26 PM
Jenzpony's Avatar
Jenzpony
Shelty, gas station here just started carrying ethonal-free gas! 30c more a gallon, but worth it!
stock 91 GT, 25-30* weather. 28mpg highway. automatic/2.73 car. cruise doesnt work(ahem, timspony. that would be a nice surprise when i come home!). I think it could have easily gotton 30mpg if we werent cruising at 75
Old Jan 24, 2009 | 04:09 PM
Shelty's Avatar
Shelty
wow. I wsh they would bring that stuff down here... I miss the good stuff, and believe it or not, Ive never seen an E56 gas pump anywhere...
Ive always wondered if you could build a nice "flex fuel" stroker motor... or is all that flex fuel calibration handled by the ecu?
Old Jan 24, 2009 | 05:00 PM
zippo2341's Avatar
zippo2341
i do mine everytime i fill up, i went from 22 average to 19-20, ill usually smoke a cig outside the dorm when im done ill jump in and go, so it gets about 5 minutes to warm up
Old Jan 24, 2009 | 05:13 PM
86 5.0L's Avatar
86 5.0L
something tells me to call BS....
Old Jan 25, 2009 | 12:31 AM
94Blk5.0's Avatar
94Blk5.0
5-10 minutes seems like an awful long time to let it warm-up... I usually let mine run for a couple minutes and let the idel drop, then take it really easy.
Also, wouldn't defrosters blowing hot air be using heat from the coolant w/o compressor involment?
Old Jan 25, 2009 | 02:01 AM
86 5.0L's Avatar
86 5.0L
without the dryer in the A/C system that hot MOIST air will fog up your windows even more
