starter sticking open with key off
I am having a issue with the starter of my mustang when i crank it will stick and keep going even if i turn the key to off, then i have to pull the battery cable to get it to stop. I have replaced the ignition switch, starter, starter wire, and celoniod ... Anyone know why this is doing this
you need to grab a test light and see if current is still being applied to the starter side of the selonoid when prob occurs, if it is then quickly see if current is on the ignition /small feed wire, if none, and or no current on both then = bad starter bendix, if current on starter wire and not on ignition feed = bad selonoid and or cheap china one
Sounds like the solenoid but you said you've replaced it ? Next time it happens tap the solenoid with a screwdriver handle and see if it stops, our car has been doing that off and on lately and it's the solenoid, if I tap it with a screwdriver it comes unstuck and stops cranking
lincolnshibuya
Dec 8, 2015 04:37 PM
BeatnikFink
Oct 1, 2015 08:00 PM
logan409
Sep 26, 2015 07:43 PM
