to turbo or not to turbo...
hypernumatic (sp?) pistons and 93+ mustang = not forged
well depends on the stuff you actually buy and how much you are actually fabricating yourself. if you look at my thread "you all wanted to see it" my neighbor is doing a 100% DIY turbo build which he is almost done. he's going to be around 1k in parts when done maybe around 1300ish once he either gets wideband or a tune done.
so a turbo build can be had from 1k and up. most often i hear abuot people spending around 2k on a DIY and if you get a kit, depending from where its goin to be 2500+ just for the kit.
i dunno. i just say hyper
hyper = children
children = inefficient
so
hyper = inefficiency
therfore
hyper pistons suck
(side note to all you pro hyper piston people. i know there is nothing wrong with them but they have limits just as forged do to too depends on application and use)
hyper = children
so
therfore
hyper pistons suck
hyper = children
so
therfore
hyper pistons suck
hyper = children
so
therfore
hyper pistons suck
Nobody can be sure what a car will run. When I thought my car out and before I ordered the fisrt part I planned to build a car that would run 10.50's but until it hits the track and dialed in I could either be pleasently surprized or sadly disappointed. I've built enough cars to know it happens both ways. Sometimes it's better sometimes it worse. I built a 461 Cubic inch 69 Chevelle once that I was shooting for low 12's on a very modest build with 78 truck Iron heads with mild porting and a mild solid roller cam (Comp 288 street roller) Performer RPM intake Turbo 400 and 4:10 gears in a 3500 lb car and it busted off an 11.29 @121mph right off the trailer with the carb right out of the box. Then again I've put together some mid 9 second 540 Chevelles that took 20 passes and a lot of trial and error just to get out of the 10's. It can be good, bad or downright ugly. I've seen guys build some of these twin turbo cars and paxton, vortec and other blowers on their street cars and every now and then someone hits up on the right combo and it runs like a rocket. I know more guys who are sadly disappointed with the performance if their turbo car than really truly happy. Most of them can get a good trap speed but in most cases a N/A high power car gets to the mark first. I've been racing a long long time and I've never owned a built Turbo car but I've sure put a boatload of them back on the trailer. I'll take big cubic inches and a well set up car anyday over a finicky turbo car. If I wanted to dyno race I'll hang a couple of hairdryers on mine and pull up on the rollers, lol
hyper = children
so
therfore
hyper pistons suck
hyper = children
so
therfore
hyper pistons suck
